I have a 2010 clio 1.5 dci that requires a Turbo Pressure Solenoid Valve
Does any one know where this unit is situated on the car?
Turbo Pressure Solenoid Valve FOR Renault Clio 1.5 dCi
Re: Turbo Pressure Solenoid Valve FOR Renault Clio 1.5 dCi
Sorted it out........problem was when putting your foot down to climb a hill or overtake the Turbo would drop out, the car would loose power and the service light would illuminate along with a dash message "check injection "
The Turbo pressure solenoide has a rubber diaphragm in it that can perforate or split with wear. It works on air suction from the intake manifold and if it fails it basically stops sending a variable voltage signal to the ecu. The car does not stop revving fully or go into limp mode if this solenoide fails, it just does not pull as hard or accelerate as quickly as it should.
The Solenoide is situated on a metal bracket just to the left of the cooling fan and coolant expansion tank. About half way down the radiator and air conditioning radiator in the middle. It's a simple job to do. 2 rubber tubes and a 2 wire connector to disconnect and reconnect to the new unit. The Solenoide is rubber mounted. It just pulls upwards and slides of the metal bracket it's mounted on.
Hope this helps someone.
- New User
Hello, just made an account to say this : Thank you ! it helps !
Just received my new turbo solenoid valve, i had an red engine check light intermittent error , only when pushing hard on the engine
That's fantastic. It just shows that if people share their problem AND FIXES we can all save money and frustration. Take care.
