Hi all
First time poster here. I tried to search but couldn't find anything but may have searched badly.
I have a 2010 Citroen c3 and the heating fan doesn't seem to work. The vent in the drivers footwell has a small amount of heat coming out of it.
It doesn't matter what speed it's set on or auto. I have recently had a full service and it seems to coincide with that. Could something have been disconnected?
This car is hemorrhaging money and would love this to be an easy fix I could do.
Thanks in advance for your help
Citroen C3 heating fan
Hew
- New User
Reason: Corrected 'Citroen' to aid searching
quintet
- x 44
Re: Citroen C3 heating fan
Hello & welcome to the forum. The search facility can be a little hit and miss. If your car has been serviced i think it unlikely anything will have been disconnected, the only things i can think of off the top of my head service wise is, has the pollen filter been changed? a dirty one will restrict the airflow but this will have been ongoing from before the service, or did you have the coolant/antifreeze changed? If so it may be airlocked.
However i think it more likely the heater motor resistor has packed up, have a look through this FCF thread. viewtopic.php?t=30102
Music keeps me going.
- x 1928
Hi and welcome to the forum.
Can you clarify what you mean by this? Is the fan running at all and, if so, what sort of speed? Does the driver's footwell vent blast out air but it's not very hot or is it quite hot but only coming out in a trickle?Hew wrote: 04 Mar 2021, 21:24I have a 2010 Citroen c3 and the heating fan doesn't seem to work. The vent in the drivers footwell has a small amount of heat coming out of it.
