Xsara Picasso electrical problem
Brian60
x 3
Unread post by Brian60 »
Yesterday the Pic wouldn't start just a click from the starter solenoid. Dashboard went really dim I checked battery voltage and it showed under 11 volts, on turning the key it dropped to 8 volts. So today I have been out and bought a new fully charged battery.
Its now in the car but I get the red ignition light and economy mode active on the dashboard. But the starter still just clicks and wont fire.
Can anyone tell me what I have overlooked please.
Rhothgar
(Donor 2026)
x 221
Re: Xsara Picasso electrical problem
Unread post by Rhothgar »
Sounds like the starter motor is jammed in mesh would be my first thought.
If it's easily accessible, then disconnect battery, unbolt it and clean the internal screw shaft and make sure that the pinion gear which engages with the flywheel moves freely along the shaft. That would be my first shot at trying to fix this.
Alternatively, you can for starters, try disengaging it by hitting it repeatedly with a hammer to try and shock disengagement.
Also check earth strap to engine.
Brian60
x 3
Thanks, I'll give the starter a look over.
x 1939
Unread post by Paul-R »
If it is a jammed starter motor and it's a manual gearbox you could putting it in gear and then rocking the car back and forth to jar the starter motor.
x 1490
Are you sure the new battery is charged..... sounds like it might not be!
Brian60
x 3
FOLLOW UP.
I did the simple rocking the car to make sure it wasn't jammed.
It was as RichardW said not fully charged as per packing said it was! I borrowed a booster from a neighbour and it started immediately, so I checked voltage of the new battery, 11.8 volts. A couple hours of battery charging and its now back to normal.
So thanks everyone for the helpful suggestions, sometimes you forget the simple solutions yourself and need someone else to prod you in the right direction.
Rhothgar
(Donor 2026)
x 221
Often the most simple solution.
I never want to suggest something so simple because I like to assume people have checked the very basics...
go2hell
Unread post by go2hell »
Occasionally, some battery terminals are loose and same issue occurs in XP's.. regards
