407 with Retrofitted RNEG, will AC off work?
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
Moderator: GiveMeABreak
Post Reply
ree_dk
My Cars: 407 SW 3.0 V6
Expert Tepee
Post by ree_dk »
Hi all
I have a 407 SW with a factory installed RT3. I want to have BT and updated maps so I am planing on installing an RNEG unit. I have bought an adapter and all other parts needed. But I need to figure out if I can still turn the AC off and have visual climate controlles as this is done in the menu of the RT3 unit. Can someone tell me if this can be coded to work on the RNEG/RNEG 2 units. I am aware that I need the CAN2004 edition.
Thank you all I advance :-) 🙏🏽
Br
Christian
Post Reply
