Citroen C4 No Crank No Start
maverickmk
Unread post by maverickmk »
Some advice please community.
Citroen C4 diesel 1.6 no crank no start I have attached the scan results. Cleared the errors and scanned again-so two scans attached.
http://s000.tinyupload.com/index.php?fi ... 1501348877
http://s000.tinyupload.com/index.php?fi ... 6410442110
Regards
Mitche
x 1485
Re: Citroen C4 No Crank No Start
What spec is the car? Fault in there about hybrid drive, but there isn't a hybrid C4? Is the battery OK? Have you checked the underbonnet fuses? There's a 20A that covers the starter solenoid, prone to popping when the starter gets a but older.
maverickmk
Thanks RichardW. Turns out it was the battery. Rookie mistake taking a hammer to an egg.
x 1485
All those myriad faults was looking like l low voltage. Always worth starting with the simple things!
