Berlingo 1.9d problem
kieranhaw91
Unread post by kieranhaw91 »
Hi, I have a 55 plate Berlingo van with the 1.9d engine that is having trouble. The van won’t Rev past 2-3k and smokes badly (some black some white). It won’t up over 40mph once I’m through the gears up to 5th. I recently serviced it with new oil, all filters and glow plugs. Also had a new MAF sensor fitted recently. Anybody had these symptoms before?
Thanks in advance
x 1056
Re: Berlingo 1.9d problem
Unread post by wheeler »
Take the air intake pipe of & make sure the vaccum operated butterfly stays fully open when the engine is off, if you manually close it it should spring back open. Start the engine & make sure it doesn’t stay constantly closed when the engine is idling.
