Diagbox v7.57 and 2013 Cit. Dispatch...
ekjdm14
x 256
Unread post by ekjdm14 »
Hi all, just recieved a PM about Lexia/DB usage & wondering if my kit will be able to do what's needed. The message reads-
Good evening, not sure if you can help I've refilled my dpf fluid tank Dispatch van 2013 and need somebody to help with resetting the ecu counter. Have tried with a snap on solus handset but it wouldnt communicate so Im hoping the proper kit might?
I'm currently running 7.57 but can update if needed, but main issue is I don't have the S.1279 module. Is this strictly necessary to reset the fluid counter on the above vehicle?
'96 ZX SX 1.9TD, White, 88k
'98 406sw 1.9TD, Cherry Red, 197k
'98 Ford Fiesta 1.3i 72k
'93 Ford Granada Scorpio 2.9i 135k
x 1918
Re: Diagbox v7.57 and 2013 Cit. Dispatch...
Unread post by Paul-R »
IIRC your interface isn't full chip and that might be relevant.
x 6954
You may also need the S1279 add-on interface for commercials to read all the ECUs.
x 1056
Unread post by wheeler »
The S1279 is not used on the Dispatch/Expert.
Only the Relay/Boxer & the Nemo/Bipper need this.
ekjdm14
x 256
Brilliant, that sounds hopeful. My kit ain't full chip but the fella works nearby so will give it a shot. Worst case is we can't get it reset.
Thanks all.
x 6954
Yes, no Fiat influence on the Dispatch, so no need for the S1279 as Wheeler mentioned.
