We've just added the Bosch diesel injection pump technical guide to the Resources library.
The very readable 66pp booklet covers all the VE pumps, from all-mechanical to ECU-driven versions, explains how each works, and includes adjustment, timing, repair and checking info.
The downloadable and printable pdf is in the Members' Area > Resources > Citroen Mechanic's handbooks section, at the bottom of the table.
If you're a forum Donor, you'll have full access to this area.
Resources - Bosch diesel pumps
KennyW
- x 165
Re: Resources - Bosch diesel pumps
Add that to Citrojims strip down guide. Everyone is a winner
Kenny
Kenny
C3 1.4 petrol (SWMBO)
Rhothgar
- (Donor 2026)
- x 222
So excited to see this as I have made some adjustments to my pump and it smokes like a bad 'un now!
However, the link does not find the resource...
Just need to have a good look at the guide to be able to use the requisite proper technical terms. It is a VP20 pump I believe with the electrical cold start advance and also a waxstat. Maybe cold start advance is still receiving 12 volts after car is warm and still allowing more fuel through if that is indeed how it works.
Issue starts at around 4 minutes!
https://1drv.ms/v/s!Ar8AkvzZJWl9_A75v95Q1AgiNjo4
- x 1746
Marc,
Could you have a look at the mega.nz link for the Bosch booklet, as 'file not found' appears.
Thanks, C.
Thanks, C.
- x 6950
I've sorted the link out Chris, resource is available again.
