Fap/dpf reset using Solus?
Qplate
Unread post by Qplate »
Hi all not sure if anyone can help have attempted to reset fap level (2013 Dispatch 2 Litre) with a mates Snap on Solus kit today but kept getting a no communication error with that particular module. Connection was fine otherwise systems check o.k just couldnt get into the particle filter fluid reset? There's a 30 amp fuse for fuel & emmisions control thats ok. Any other suggestions? Thanks in advance
x 1056
Re: Fap/dpf reset using Solus?
Unread post by wheeler »
Are you trying to reset the soot content in the DPF or reset the additive fluid level?
Qplate
Hi, sorry it's to reset the additive level put 3 litres in.
x 1056
The menu for resetting may be in the injection ECU as some models dont have a separate additive ECU. Ive only used Solus a couple of times so can’t really help more than that. In aftermarket diag tools is usually under service actions or words to that effect.
Qplate
Thanks for the info, we'll have a look
Regards AL
