I'm trying to fit cruise control to a 2007 1.4 16v KFU engine non vvt..
I can access the engine ecu with diagbox.. Pp2000 won't access it.. I've switched cruise on in the bsi but when I change the engine ecu to cruise present it won't program and says programming failed. The clutch switch is present. Am I missing something or will it not do it. The car is an, SE Premium with glass roof.. Auto headlights auto wipers.. Auto rear view mirror.. Dual zone ac.. Etc.. Its just missing cruise to make it complete..
Any ideas. Thanks..
207 1.4 16v diagbox issue
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
OnlinePaul-R
- x 1942
Re: 207 1.4 16v diagbox issue
Where did you get the overdrive switch from? I believe there are different types which all look the same.
citroenxm
- Fallen Hero
- x 70
Sent to me from a mate. Could that be an issue. When it's sitting at home. It recognises the button presses and say cruise control impossible.. And the dashes above the milage where the cruise set speed would be flash.. So the stalk works..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
