Hi, i recently switched my RD4 to RD45 and i noticed two problems.
1. I lost parking 'beep' sound when on reverse gear. Parking sensor display works as before.
2. Whenever i turn on the radio by pressing the button i hear weird sound coming from all the speakers, it lasts for about 2 seconds and then radio works. Even weirder, the same sound appears when i open the car with the key (central lock).
I recorded it, just please listen it up (something similar to bass sound)
https://video-waw1-1.xx.fbcdn.net/v/t42 ... e=600C9B9F
When i switch to my old RD4, i don't have this annoying sound and the parking 'beep' back.. The RD45 i bought is coming from disassembly an another peugeot 207, the seller coded my vin to it's.
Does anyone met with something similar? Rewriting vin gonna help?
Weird noise from speakers on turning on RD45
- x 6960
Re: Weird noise from speakers on turning on RD45
Coding the VIN is not sufficient! That only codes it to the vehicle. You need Peugeot Planet or Diagbox to re-configure your factory options for the RD45 as your Multi-Function screen ECU and BSI were setup for an RD4 unit.
Ventori
Fixed via diagbox.GiveMeABreak wrote: 23 Jan 2021, 22:24 Coding the VIN is not sufficient! That only codes it to the vehicle. You need Peugeot Planet or Diagbox to re-configure your factory options for the RD45 as your Multi-Function screen ECU and BSI were setup for an RD4 unit.
- x 6960
Good - glad you have sorted it
