405 CV joint
delboy
405 CV joint
Unread post by delboy »
I need to replace my N/S outter cv joint. Does anyone know how the joint is helt to the shaft. I have only replaced a vauxhall and that was held by a spring clip.
Many thanks.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
If it's similar to the BX, and it's likely to be, the joint will be held by a circlip. Give the joint a smack, outwards to release it. Hold the drive shaft,or it might pull from the gearbox.
delboy
Thanks John. just what I wanted to hear.
Homer
x 16
Unread post by Homer »
Make sure you have a couple of new circlips before you start. The old one is liable to be brittle and you are almost certain to bend the first one when you put it back together.
macaroni
Unread post by macaroni »
I have a whole, unused, N/S GKN driveshaft for a 405 for sale if you like.
£25
