cooling fan won't shut off
508c5
x 4
Unread post by 508c5 »
Hello,
Peugeot 508 , 1.6 thp. 156 bhp
The cooling fan won't shut off after a drive (I disconnect the battery for it to stop). it is not the usual 1-2 min idle work after a drive. it also kicks in very early after starting the motor.
engine coolant temp. run low (about 73C, instead of 93C). no faults found on my computer scan.
any ideas?
does anyone know where the assigned relay and fuse are located? the owner's manual does not specify this.
thx.
