fault code P0093, P149C, P1496 & P0215
derbyshire1970
Post by derbyshire1970 »
Good morning can any one offer any comments on Fault code P0093
Incoherence in the fuel pressure with the flow regulator blocked open
Fault code P149C Variable geometry turbo charger
intermittent
too large deviation on the last initialisation of the lower limit
P1496 Turbo position signal to far from the refence value turbo charging to great - Intermitent
P0215 Principle relay poor operation of the relay the ECU is not being supplied as it should be - intermitent
