Hi, I have a 1974 Citroen DS23 Safari and the brakes have a delay from when the button is pushed to when the brakes apply. What do I need to do to rectify this?
Thanks in advance.
1974 Citroen DS Safari 23 brake delay
- x 3296
Re: 1974 Citroen DS Safari 23 brake delay
I would bleed the brakes, just in case any air has got into the system. How is the suspension?
tony trans am
Suspension is fine, just the delay on brakes, can be quite scary.
- x 1468
Is the level not checked with the suspension at the highest position?
- x 6945
Yes you are correct Mike, the Hydraulic fluid level should be checked with the suspension on high on a DS!
- x 3296
Please accept my apologies on that, I was confusing it with my C5. You are BOTH correct, and I am not!
- x 6945
In fact I've deleted that whole post James as on the DS I believe the Braking circuit is also linked with the suspension and Steering. This was at the time before the systems were separated.
- x 6945
You may already have this, but there's info on bleeding the circuit here:tony trans am wrote: 17 Jan 2021, 19:28 Suspension is fine, just the delay on brakes, can be quite scary.
http://www.citroen-ds-id.com/hc/files/H ... 0Guide.pdf
