hello! I have a very big problem with the DS5 gearbox. 2.0 Disesel. The gearbox gives me a kick or a wild kick with the colpo when I send it to D.
the car gives me coding. It starts with momentum. departs very harshly. as if someone was hitting me from behind. I changed the original citrus oil. they told me that there are problems with the solenoid valve. i bought them new block. now the car has the same problem.
after diagnosing it does not cause any problems. does not enter any code.
Aisin Tf80sc
I spent a lot of money. I also sent it to the mechanic, he opened the truck and did not find any problem inside. Please who has information to help me.
the gearbox gives me hits
JamesBishop
Re: the gearbox gives me hits
Hi! I saw that this is better covered under Ds/ gearbox topic. Hope it helps. Thank you!
