Which diagnostic tool, PP2000,LEXIA3 or DIAGBOX
Kenmac15
(Donor 2022)
x 4
Unread post by Kenmac15 »
What are peoples recommendations for PSA diagnostic tool for my C5, PP2000,LEXIA3 or DIAGBOX ??
Ken
“I have not failed. I've just found 10,000 ways that won't work.”
x 3296
Re: Which diagnostic tool, PP2000,LEXIA3 or DIAGBOX
I have an earlier version of the Easy Diagnostics equipment, which I have found very useful. It is NOT the cheapest, but it will have the full 'opto-coupler' set, so it should work on most PSA vehicles (although for Fiat derived vans you will need an S1279 module);
https://www.easydiagnostics.co.uk/produ ... t-vehicles
https://www.ebay.co.uk/itm/S-1279-Modul ... Swj0tf0doL
viewtopic.php?t=60113
x 6945
Kenmac15 wrote: 09 Jan 2021, 20:06 What are peoples recommendations for PSA diagnostic tool for my C5, PP2000,LEXIA3 or DIAGBOX ??
Diagbox is the later version of the software that contains both the older Lexia and PP2000 for Peugeot (encapsulated software that will auto launch according the the vehicle and build date). So you only need to focus on Diagbox. Version 7 is fine and then upgrade that to 7.58 and you will be ok. Just make sure the hardware is full chip CAN compatible.
Kenmac15
(Donor 2022)
x 4
Well you were right as I purchased Lexia from easydiagnostics & had real problems with my laptop & software issues (my laptop causing problems not Lexia) and the service was beyond anything I've ever experienced before and we're all up & running, but if this had been an ebay purchase I would just had to throw it away as the support I needed wouldn't have been there.
I cannot recommend them highly enough.
Ken
x 6945
No worries, Jim is very helpful and there's a lot of support here from members if you get stuck.
