Citroen c4 cactus fan motor
Nunnleyj
New User
Unread post by Nunnleyj »
Hi I was just wondering if anyone knew where my fan motor is located as my fan system in my car isn't working and with it being winter it's really cold inside
Citroen c4 cactus 2014
x 6945
Re: Citroen c4 cactus fan motor
The fan motor is built into the fan! If you are referring to the electronic control unit, these are mounted to rear of the fan assembly, top right at the rear of the housing as you stand in front of the engine.
x 1488
I think the OP is talking about the internal blower, Marc? In which case it's one of the awkward ones that is in the front of the heater unit up against the bulk head, accessible after removing the glove box no doubt....
x 6945
Of course - a terminology issue again. I usually refer to this as the 'Blower Motor' :-D
R1310
Unread post by R1310 »
RichardW wrote: 07 Jan 2021, 17:41 I think the OP is talking about the internal blower, Marc? In which case it's one of the awkward ones that is in the front of the heater unit up against the bulk head, accessible after removing the glove box no doubt....
Hi, just wondering if theres any chance you may explain a bit more how to access the resistor? Is it also by removing the glove box? Thanks in advance
x 1488
It appears to be on the same side of the heater box under the fan, so either glove box or may be accessible if you remove the trim piece underneath.
