Hope someone can help me:), I have been getting issues with my Peugeot 3008 Diesel 2011 which keeps going into limp mode I know this is a common problem. When it happens you cant drive it, there is no power and engine just runs terribly
1) P0268 State : intermittent, injector 3 control, short circuit between two wires ( the intermittent was permanent previously so that has changed)
2) U1208 State : intermittent fault in communication with the engine management ECU or with the drive train interface ECU, data invalid
3) C1391 State: intermittent non-confirmation of engine torque, not characterised
3) U1213 State intermittent fault in the information transmitted by the ABS/ESP ECU value received incorrect
What should I try next?
I am of thinking of taking the injectors out and giving them a soak in carb cleaner and changing the seals on injectors, not sure what else i need to purchase? Has anyone successfully fixed this issue by removing the injectors, cleaning then reinstalling? I have seen a few videos of stripping the injector completely down then cleaning all the parts and reinstalling. Has anyone tried this method successfully? I don't think replacing them is worth the cost so am willing to try. Any suggestions of what i can try?
