Hi all from Ricksw77
Ricksw77
Hi all. I consider car enthusiast and like to be able to do my own revisions, reparations, etc. I have Peugeot 308 sw model 2011. ( 9 HP, 4E_4H OR DV6DTED) At this time I intend to place indicator in parallel with the heating of the mirrors with an LED that will indicate fap regeneration. Can anyone indicate electrical diagram to put this connection under the steering wheel? Thanks. Regards Rick
- x 6963
Re: Hi all from Ricksw77
Hi and welcome.
That's not going to help as the power consuming equipment is not always activated by the engine ECU for regeneration - only if the conditions require it, so that won't really be reliable.
Ricksw77
Hi .
What I intend to do is to find out the positive that feeds the resistance of the side mirrors and put an LED in parallel, because I know that whenever regeneration enters service it also turns on (the resistance of the mirrors), but this linkpreferred to do under the steering wheel. Is it possible to have some info with cockpit electrical scheme. Good New year 2021. Regards Ricksw77
