I believe that, if the Webasto unit malfunctions, it can usually be reset by disconnecting the power supply to it for a few (10 ?) seconds.
Unfortunately, according to the handbook, I can’t see any fuse for the unit. Does anyone know an easy way to disconnect the power to the unit ? I guess I could simply disconnect the block connector by the Webasto but, with current temperatures, I don’t really fancy grovelling under the car - is there any more comfortable option ?
Cheers
Julian
Webasto heater fuse ?
jml
- Locked user account
- x 37
Julian Leyton (RIP) 2023
- x 1044
Re: Webasto heater fuse ?
why not just disconnect the main battery ? it will do the same job.
https://www.frenchcarforum.co.uk/forum/ ... 51&t=61997
jml
- x 37
Yeah, thanks for the suggestion. I’d thought of that but I didn’t want the possible faff of resetting windows / doors or anything else.
Cheers
Julian
Cheers
Julian
- x 1044
It's really not a faff, all you need to do is reset the clock, put each window all the way down then up again, switch the ignition on with each remote & press the lock button.
jml
- x 37
Thanks for that - in 165,000 miles I have never once had to reset anything (oh, apart from driver’s window once or twice) so I wasn’t sure what I might be letting myself in for
However, luckily, I was able to clear a fault code with a cheapish reader I’ve got and all is now working ok.
Thanks for your advice,
Cheers
Julian
Cheers
Julian
