Peugeot starting problem
Foxies
Hi all .any help would be great.i have a Peugeot 206 2.0 hdi that I bought for work of a young lad that he had put petrol in by mistake. I have done all the necessary cleaning and it runs now but is murder to start I have to wind it up for some time to get it going. Once going it's fine. Here is the list of jobs I have done, sorry to bore you. Changed filter.changed the crank sensor.changed the battery. had the starter checked it cranking fine. Done a done a diesel drop off test and all containers filled pretty much the same. Replaced the glow plugs. Think that's it. Once started it runs ok but stop it even after a good run and it will not start again without cranking it for ages. No that I like using it but with a little easy start it starts straight away. Any help please would be great. Cheers.
- x 1056
Re: Peugeot starting problem
Can you get it on diagnostics & read the live fuel pressure when cranking?
moizeau
- x 429
Compression test may help
Pete
- x 3302
I wonder if the fuel pumps have taken damage? Diesel helps to lubricate them, but petrol does not. This does not mean you can lubricate the pumps yourself.
Foxies
Thanks for reply will give that a go
Foxies
Hi done a live data crank test and it very low. Is this the injector pump or could it be a sensor. Cheers.
