Scenic Headlight Adjustment
Matt20102012
New User
Unread post by Matt20102012 »
Hi i have a GS MK3 Privledge and i need to locate the headlight beam manual adjustment screws. I have found one but this only moves the main beam but need the dipped beam adjusting. I have just put LEDs in the dipped and currently they are skywards. Any help please TIA
x 1943
Re: Scenic Headlight Adjustment
Unread post by Paul-R »
Speaking generally, adjustment of the headlamps does both main and dip at the same time. It's not possible to do one without the other. It's either a problem with the bulbs not being seated correctly in the housing or the bulbs themselves have been badly made.
I have LED H7s in our 308 and didn't do any realigning. What make are your LED bulbs? Mine are Philips.
