Replaced engine
Ceenine
x 17
Replaced engine
Unread post by Ceenine »
When an engine is changed in a car, is there any pairing required of the ECU with Diagbox? I was thinking yes.
Using the engine no. of a vehicle, is it reasonably easy to determine the date of manufacture without contacting Peugeot importers?
Steve Walsh
x 518
Re: Replaced engine
Unread post by Steve Walsh »
I would have thought it would be best if you used ecu and bsi etc from donor car, Someone with more knowledge than me will be along soon no doubt.
petarc1971
x 10
Re: Replaced engine
Unread post by petarc1971 »
There is no pairing only if the nozzles with the engine have arrived so that the code can be entered in the engine ecu, if it is only the engine then there is no pairing.
