Berlingo Multispace Factory Alarm Retrofit
Argos69
x 53
Unread post by Argos69 »
Hi all,
Just been acquiring a fresh Berlingo in the form of a 2017 Multispace Flair 120 with 21000 on the clock.
I noticed it has central locking as per my Enterprise van, but not the factory alarm, as the van came with.
I've searched the forum but not found anyone who's added this bit themselves, so I'm wondering if this is for a very good reason?
I know the easy way out is to get some aftermarket kit etc, but the Citroen unit on my van gave 8 trouble free years, without a single false alarm or fault, so I'd prefer the same again if possible. Also I wondered (hoped!) some of the wiring might already be there.
Does PSA make a kit, as I can only find some parts available online?
As usual, opinions and good ideas are always welcome, so thanks in advance!
2010 Land Rover Freelander 2 HSE Automatic
2013 Citroen C5 Tourer 2.2HDi Exclusive
2017 Citroen Berlingo Multispace Flair 120 Gone!
2012 Citroen C5 Tourer 1.6HDi 6 Speed (sort of auto!) Gone!
2012 Citroen Berlingo Enterprise 1.6HDi Van Gone!
2001 Range Rover 4.6 Vogue Gone!
Argos69
x 53
Re: Berlingo Multispace Factory Alarm Retrofit
All quiet, so I guess nobody's done this. Maybe there's a good reason...
I found a .pdf online a while ago, which seemed to show an aftermarket kit with the Peugeot logo on it. It showed a step by step guide with a variety of part numbers. It also showed the use of some existing wiring, but also an extra section in the kit, which went to the siren. It showed the inner wheel arch shield coming off too. I thought I'd kept it, but looks like I haven't and typically, I can't find it again....
Going to a Citroen dealer tomorrow for a warranty checkup, so I will ask the question whilst I'm there.
x 1055
Unread post by wheeler »
That sounds like the dealer fit accessories alarm, made by Meta if I remember right. It’s mainly a plug in job but some extra bits of wiring need to be added. Works off the original remote.
