leaking Xantia steering rack 1.9 TD 1995
johntaylor
The rack is leaking on the nearside steel push/pull rod. The seal is located on the main housing where the rod slides through. Can I replace the seal in situ? Can the rod be removed without specialist tools? If I remove it can the seal be replaced easily? Any help will be appreciated.
Dave Burns
johntaylor
Thanks for that...will get one from breakers.<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Burns</i>
The power steering ram is a sealed unit I'm affraid, only options are a used one or a new one.
Dave
Dave
