Diagbox cleaner
freo
Diagbox cleaner
Hi, anyone know where i can find diagbox cleaner?
petarc1971
- x 10
Re: Diagbox cleaner
If you need to uninstall, you enter the folder where the program is installed, where you can uninstall.
freo
Re: Diagbox cleaner
Yes i have uninstalled it but i think there are some registerfiles and other files that you need DBcleaner to get rid of.
- x 6956
Re: Diagbox cleaner
I've sent you a link vi PM.
freo
Re: Diagbox cleaner
Thanks! installation seems to work fine now after cleaning.
Chris2cv
Re: Diagbox cleaner
Hi I have the same issue need to uninstall and re install does anyone have the link for the cleaner
shelleyamy
Re: Diagbox cleaner
Hi Marc
Old post i know, but i am trying to get my Diagbox working on an old Macbook.
Got to the "easy123" validation issue. I had my WIFI switched on during the first attempt.
So now i need to clean out the old version to try again.
Do you still have access to the "cleaner"
Ta
Mike
Ta
Mike
modeslow
Re: Diagbox cleaner
Have u tryed not uninstaller use it but cleaner?
cit-rotti
- x 77
Re: Diagbox cleaner
A native version of Diagbox can only be installed on a Windows operating system. Depending on the software version, a 32-bit version or, for newer software alternatives, 64-bit versions are mandatory - they should always be Pro versions.shelleyamy wrote: 11 Dec 2024, 14:27 Hi Marc
Ta
Mike
VM software versions of Diagbox are possible with the appropriate VM installation for MAC - if the MAC operating system allows this.
Depending on which software version needs to be deleted, there are different DIAGBOX Cleaners - at https://guiapsa.foroactivo.com/login
software + additional programmes can be downloaded.
Greetings Wolfgang
shelleyamy
Re: Diagbox cleaner
Thanks's Wolfgang, got it up and running now.cit-rotti wrote: 12 Dec 2024, 21:11A native version of Diagbox can only be installed on a Windows operating system. Depending on the software version, a 32-bit version or, for newer software alternatives, 64-bit versions are mandatory - they should always be Pro versions.shelleyamy wrote: 11 Dec 2024, 14:27 Hi Marc
Ta
Mike
Greetings Wolfgang
Using Bootcamp running Windows 7
Ta
Mike
