Berlingo - Cruise control retro fit
madted21
Unread post by madted21 »
Hey all
I have read through old posts as best I can and can see nothing exactly related. I'm looking for someone with the lexia/program to help me with installing cruise control on my 2013 auto 1.6 e hdi Berlingo multispace xtr airdream.
I understand the theory and what to look for with regards to pedal wiring etc. I have the hole for the cruise control and am happy to wire it in.
But I don't have the right gear/program/experience for the programming side. I was going to fork out for the programming equipment and give it a go, but I thought rather than pay an internet shop, if someone else already had the gear they could earn a few quid instead. I am in Dorset and happy to travel within reason.
Drop me a message if you can help and want a few pounds in your pocket 👍
Cheers
Hagrid
x 3
Re: Berlingo - Cruise control retro fit
Unread post by Hagrid »
There should be an interactive map of Lexia owners on here somewhere. Sure I saw it a while ago.
You're probably saving yourself a very big headache by not installing it yourself - I've been going through that with the same aim in mind (but for an M59), and it ain't much fun!
I'm nowhere near Dorset either - sorry!
UPDATE: here it is!
viewtopic.php?t=56452
Shows one chap in Christchurch.
madted21
You are literally a lifesaver! I went through posts for cruise control retro fit but not the programming software specifically.
Thank you so much!
Hagrid
x 3
:wink:
madted21
Just as an update, not sure if I was just plain lucky or someone was smiling down on me, but I plugged the stalk in and it works straight off the bat!
Very happy Berlingo owner!!
Thanks for those who PM'd/responded on here.
Cheers
admiral51
(Donor 2026)
x 392
Unread post by admiral51 »
Hi madted21
Glad you got it sorted, sorry i was a little late to the thread.
I am in Dorset and have a Lexia but not 100% sure i have the correct adaptor for the Berlingo, something tells me it is FIAT based.
Happy to help if i can
Colin
x 6947
The Berlingo stand alone is PSA Colin - no FIAT influence on these, only some of the commercial Vans and the Nemo, Bipper which is the same as the Fiat Fiorino, so no need for an adaptor on the Berlingo for future reference. :wink:
admiral51
(Donor 2026)
x 392
Thanks Marc i remember something about an adaptor needed for a campervan conversion so just wanted to check i was not saying i could do when i could not :)
@madted21 PM me if you need any help not about during the week but weekends are ok usually
Colin
madted21
Hi Colin
That's really kind of you. The cruise control is in and working thanks, very pleased that it didn't require further work but it is kind of you to offer.
My next project is to install heated mirrors ha ha... hopefully that won't need software work!
Thanks again
admiral51
(Donor 2026)
x 392
No problems Neil just yell if you need some help with Lexia sure we can work something out
