Radiator fan and internal blower not working
Steveath
- New User
Good morning I was driving Along fine then an engine fault message come up on the Dashboard I got it checked and it says no communication to radiator fan I’ve had the fan checked and the resistor both Working fine, Since the fault appeared on the dashboard the internal fan has stopped working as well any ideas
- x 6950
Re: Radiator fan and internal blower not working
Do you mean the internal cabin blower motor - as in in turning the fan speed up on the climate panel does not operate the blower motor? What about the rest of the Climate control functions - so you have lights on and can you adjust the temperature settings? It may be that the blower control module has gone. Did you have any fault codes - if so pop them up here.
