Airbag opened
heshamderbala
Airbag opened
Unread post by heshamderbala »
Hi
I want to know why the passenger airbag open while there is no one sitting or even the seat belt is not buckled and what is the type of accident will make the airbag could open and at what speed
Hesham
x 6947
Re: Airbag opened
Not sure I understand. Are you saying the passenger airbag has fired with nobody in the seat?
Airbags are controlled by the airbag and pretensioner ECU. Exactly which airbags are triggered and the speed they are deployed depends on the impact of the crash or collision.
So if you are hit at the side of the vehicle, the front facing airbags may not be deployed at all as it would serve no purpose. The same goes for a frontal impact, which would trigger the front facing airbags but not the side or curtain airbags.
The exact speed, and the exact airbags deployed will depend on the impact zones. The airbags should never deploy without an impact.
heshamderbala
Re: Airbag opened
Hi Marc
Thanks for the reply
Actually there no one beside me and the airbag opened also mine and the speed was about 70 or 80 km/h and the accident is not huge the bumper just moved few centimeters even nothing happend to lamps and front bonnet it was in the front toward the left lamp
Hesham
x 6947
Re: Airbag opened
Ok, so that is normal - you had an impact and the airbags did their job correctly. If it wasn't a large impact, then the airbags may only of ignited at a lower speed. It is correct that the passenger airbag also went off and that is why if you have a rear-facing baby seat in the front passenger seat, that you must turn the passenger airbag off while a baby seat is being used.
