Hello guys, I just bought my first Citroen and the next day it broke down ( bad first impresion). The problem with it was that it is not running properly and even does not start! I plugged in car diagnostics and it showed me Cranckshaft sensor fault(which makes sense) but i cannot find find proper information about replacing it... I saw few videos on internet but they only showed camshaft replacements... So what i am asking for is maybe a rough explanation how to fix it and the location of the sensor!
Thank you!
1.6 Berlingo problem
- x 1055
Re: 1.6 Berlingo problem
For starters what year is it and is it a 1.6 petrol or 1.6 diesel?
Eigirdas1
it is a 2007 1.6 66kw diesel berlingo
- x 1055
The crank sensor is on the crank pulley end. It sits roughly at the 8 o’clock position on the pulley & held in with a single bolt (8mm from memory). There is a 3 pin connector on it too. Very easy to change once the plastic gaurd at the wheelarch is out the way.
