peugeot rxh 508 66 plate 2l auto
yaesujohn991a
im trying to put a dashcam in my car and trying to locate the front cigarette light fuse and a permanent live wire any help please Thanks
- x 6961
Re: peugeot rxh 508 66 plate 2l auto
A permanent live is not recommended - as if you forget to manually switch the cameras off, you risk flattening the battery (ask me how I know this).
I set my cameras up with an ignition switched fuse using a piggy back fuse kit from Nextbase and leave the camera switched on - and then everytime the engine is started or switched off the camera does the same.
The 12V accessories socket is not good anyway if you want permanent live, because it is controlled via the BSI to switch off after a time. I can't help you with this years model as the fuse diagrams are not the same to the ones available, so it might be a bit of trial and error.
yaesujohn991a
Hi mark The power box has 3 wires red / yellow.and black the red has to goto live as my cam had park mode so it takes pic when car is in park mode you can disable this but for reason when I connect all 3 wires I cant switch cam of its a viofo 129 duo Thanks
- x 6961
So the Red goes to permanent Live, the Black to Negative and the Yellow (optional) to a switched ignition that I mentioned in my post.
So it will run from battery with engine running and when the engine is switched off it will switch to a monitored state and disconnect once your battery voltage drops to the preset limit that you can configure.
So you'll need to find a permanent live and a switched live.
So the permanent live should be easy enough as most equipment only works with the engine running for the Red so pick a fuse for equipment that runs with the engine running. AS for the yellow - a lot of the equipment is BSI controlled and timed - so you'll need to do a trial and error with some fuses to see what happens after a minute of power - if it stays on for longer than a minute you should be ok.
yaesujohn991a
yes I know this I fitted this to 3 cars but it says in the manual the front fag lighter fuse is in the glovebox iv got no fuses in there just a lot of wires I cant find the fuse for the front fag lighter aall the fuses where steering are all live I cant put a pic on my fuse box
