Citroen C4 Grand Picasso II 1.6HDI 2014 Electric parking brake fault
matfyzak
New User
Unread post by matfyzak »
Hello guys. I have recently got a problem with my parking brake. It does not work at all. I tried Lexia and got this error:
C1560 00 Electric parking brake (FSE) left hand actuator
I tried to change the parking brake unit on the rear left wheel, but it did not help. Fault is permanent, cannot be deleted. Detail says that there might be a short circuit.
Any hints what could i try? Where are the cables going thru?
x 1491
Re: Citroen C4 Grand Picasso II 1.6HDI 2014 Electric parking brake fault
A very similar fault was discussed here recently: https://www.frenchcarforum.co.uk/forum/ ... hp?t=64916
Looks like the wires are a bit under spec / exposed and corrode through, suggest you get them out the sleeve and have a good look.
inzay92
Unread post by inzay92 »
Hi I have a similar issue.
How did you fix it?
If wiring issue, can it be self resolved? Does it need to go to the dealer?
