ecu
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
sheriff
ecu
Unread post by sheriff »
How do I reboot the ecu so the radio screen logo comes back onto Citroen I have tried disconnecting the battery and taking the fuse out but the codes are still on ie service thanks
x 6946
Re: ecu
You won't get a SERVICE dash warning light for any Head Unit issues. SERVICE will be for an engine or other fault (which may have an impact on the Head Unit).
You'll need to get the vehicle hooked up to a diagnostic tool using a Lexia kit with Diagbox to get a proper idea of any fault codes first of all.
x 6946
Re: ecu
The only 2 ways to reset the unit if you cannot get into the menus to do a factory reset are:
  • A long press on the on/ off button, or;
  • Simultaneously holding the volume and eject buttons
