Citroen C3 II 1.4 HDi manual transmission oil
cikavuve
Unread post by cikavuve »
Hello guys,
I wanted to make sure if this oils are recommended for 5 speed manual transmission for the car from title and if they are recommended which one is better? Thanks
RAVENOL MTF-2 SAE 75W-80
https://www.ravenol.de/en/product-range ... ae-75w-80/
MANNOL MTF-4 Getriebeoel SAE 75W-80
https://mannolusa.com/catalog/mannol-mt ... sae-75w-80
x 1490
Re: Citroen C3 II 1.4 HDi manual transmission oil
Either of those will be OK. Total is the PSA recommendation, but that's mostly a marketing tie up!
cikavuve
RichardW wrote: 20 Oct 2020, 19:42 Either of those will be OK. Total is the PSA recommendation, but that's mostly a marketing tie up!
Which Total oil is recommended?
I found multiple oils graded 75w80 and multiple specifications. Which one is needed for the car "B71 2315" or "B71 2330"?
Thank you very much
x 1490
This is the one usually recommended:
https://catalogue.total.co.uk/en-gb/pro ... R-8-75W-80
x 1746
Spec for PSA manual boxes is 75W-80 GL4.
This was Total Transmission 8 gear oil until very recently.
Now Total Traxium 75W-80 GL4+.
Both conform to PSA B71 2330 spec.
cikavuve
Thank you so much for help, I ordered 2L of Ravenol MTF-2 75w80. Hope I didn't make a mistake
