Hello everyone.
Two weekends ago my C5 1.6 at 120kmh started to sob. I gave a little more accelerator and the sobbing was bigger and the message "defective antipollution system" appeared and the engine was stopped in progress. I pulled over and tried to put it to work again but without success. It was for the mechanic the diagnosis was burnt candles (2). FAP is at 35% dirt.
A regeneration was done and the 4 candles were replaced.
Has anyone ever suffered from the same symptom?
best regards
C5 X7 Tourer 1.6hdi Problem!
- x 1941
Re: C5 X7 Tourer 1.6hdi Problem!
For anyone wondering, candles are glowplugs. The word is the same in Portuguese (and in other languages such as French).
petarc1971
- x 10
The problem is not in the glow plugs, the dpf filter is probably clogged but the engine should run in safe mode.
Tiagovp
Thanks Paul!Paul-R wrote: 19 Oct 2020, 13:44 For anyone wondering, candles are glowplugs. The word is the same in Portuguese (and in other languages such as French).
- x 1493
The glow plugs (candles...I like that!) Will not cause running troubles or depollution fault - something else is at play. Need to have another go at the fault codes.
- x 1941
Interesting fact.
In French (and probably Portuguese) spark plugs are also called the same thing.
