Well worth doing this , taking out the seats and all the carpet. One of those well hidden areas where the rust will hide and generate !.
A long overdue job, however i have come across a supply problem, the two steel plates secured in by a circular gasket in the passenger foot wells need replacing .
Where can i obtain new or new fabricated ones or is it a case of make your own ?. Also the floor rubber bungs and the brake line and fuel line clips that attach through the floor , all need replacing .
Any UK suppliers out there please.
Ta very much
205 Floor inspection, restoration, bungs and clips.
makemine205
- x 8391
Re: 205 Floor inspection, restoration, bungs and clips.
Yes, indeed
An essential job to do regularly in any PSA vehicle!
My old 205 GTi used to leak like a sieve so it was a regular job. Luckily a fairly easy one once you'd done it a few times!
