Small screen change to multimedia
This section is for General Enquiries or for Systems not Covered Above
Devon
Unread post by Devon »
Hello, I want to change mine citroen C5 2010 small screen to multimedia but do i need some additional cables or connections which connects to multimedia or no?
x 6954
Re: Small screen change to multimedia
It's not just the screen - you will need to replace the Head unit for a telemacs system, and depending on what you are thinking of putting in, will need a compatible multifunction screen (Low or Hi Resolution).
Then you will need to replace the fascia if using a MyWay, RT6 or other system that uses the large colour screen. It will also need programming and the microphone wired into the back of the Head Unit.
