Hi folks,
I have an intermittent P0656 Fault-fuel level showing up under ECU faults.
I have previously replaced the fuel filter so not sure why this has come back. Upon checking the Fuel Circuit Information, the only thing abnormal was the Voltage of Fuel Temperature Sensor showing as Value Invalid.
Could this be causing this? Please can someone advise this and also the location of the sensor?
Many thanks
508 GT - P0656
scotcruz
Re: 508 GT - P0656
Is this a rare issue? Surprised no response!
scotcruz
Re: 508 GT - P0656
OK, managed to fix this issue. Wasn't easy however with alot of research all good now.
If anyone needs a hand, PM me.
- x 1931
Re: 508 GT - P0656
I reckon it must have been fairly rare to get no responses. Thanks for telling us you've fixed it. Perhaps you could briefly tell us what you did?
sapell
Re: 508 GT - P0656
Hi I see this is an old post but I would be interested to know how you solved this issue please. Thanks.scotcruz wrote: 09 Oct 2020, 21:37 OK, managed to fix this issue. Wasn't easy however with alot of research all good now.
