C2 park assist ecu location?
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
afternoon all,
can anyone shed any light on the location of the park assist ecu?? from the info i could find, it suggests its under the drivers seat, but on popping the seat out, there are no connections there?? following the wires into the car from the back, they run down the drivers side picking up the rear lights and the speaker wires, into the front loom, then i loose where they go...
any help or pointers would be Very gratefully recieved,
citroen c2 code '09 58 reg, vin VF7**************[VIN obfuscated, can be read by forum staff] rp 11641
timmo
'58 C2 Code
'58 partner teepee outdoor
x 1056
Re: C2 park assist ecu location?
Unread post by wheeler »
Should be under the passenger seat (on a RHD model)
x 6946
Timmo wrote: 28 Sep 2020, 16:23 afternoon all,
timmo
You don't have this option on your vehicle - it's not fitted with parking assistance, so you won't have the ECU.
Timmo
(Donor 2022)
x 168
I have the ecu to fit, the wiring is there apparently, I have fitted the official sensors to the bumper and plugged them into the loom where it is clipped up at the back of the wheel arch (blue male plug on sensors to blue female plug on loom), would like to know where it is the other end to connect to the ecu, the option is there, I can activate it through Lexia although get ecu fault when you put it in reverse, which is obvious as it's not there! 🤪 So I know it will work, if I can fi d where to plug the ecu in,
'58 C2 Code
x 1056
There should be 2 plugs on the ECU. A 12 pin Blue (sensors connection) and a 18 pin black connector for power & data connection.
Timmo
(Donor 2022)
x 168
There are indeed,
'58 C2 Code
