Good morning everyone , I’ve just joined the forum and I am looking for some help please .
I have a 2009 Nemo multispace and it’s awesome but I’ve tried to fit an aftermarket stereo , the problem seems to be the harness that got sent to me doesn’t have the same pin configuration as the OEM pins , does anyone know where I can get a harness adapter or even tell me what the colours are on the original wiring as I can’t seem to find any diagrams ?
Thanks Guys
Ramsay
Nemo multispace stereo harness
- x 6950
Re: Nemo multispace stereo harness
Be very wary of changing the head unit. It is possible you may loose some Menu functions associated with vehicle configuration / trip computer if you change it. If you have the Bluetooth module option fitted, that may also be affected.
This is a CAN unit, so any connection harness you get needs to be compatible with this vehicle. You'll have to look to the Stereo supplier for connectivity compatibility.
