So, to give some feedbacks, in case it can help someone one day, or if you have some feedback to give to me
Concerning the boot, it went pretty alright. I used the stretchy boot finally, bought to a seller recommended on another topic here
http://stores.ebay.co.uk/J-R-CV-JOINTS-DRIVESHAFTS
I used the cone, so the shaft could stayed in. Still don't know which shaft I have
Also used the technique of putting a tube at the end of the cone, so you can strech the boot onto this tube, and then present the tube in front of the shaft (trick also found on another thread here
). Not a funny job, but nothing too complicated there
They say on the procedure that you need to remove the ARB drop link, but I just disconnected one side (the ARB side, as it looked easier)
Concerning the spring, to sum up, it was a nightmare... One of the worst job I did on a car
Why ? Because it is really hard to compress it... I dissassemble the broken one, and then tried to assemble the new one with a "cheap" spring compressor for few hours.... After damaging the spring (and my hands!), I had to agree that I was going nowhere...and I found a "cheap" hydraulic compressor for sale. After painting back the spring, I then I gave the hydraulic compressor a go: not that great either! It is really hard to compress in the way that you can then put the stopper on top of it: the damper and spring are hard to keep parrallel... Took me 2 hours, and again, had to paint the spring again so it will not rust (too fast).
Then, to put it back on the car, it says on the procedure: "put the top screw, then put the bottom screw". Sound easy, but it is not... I had to disconnet the ARB, and then re-attach the wheel so the weight would the hub down, and then you can "somehow" screw the spring in.... Nothing hard, but again, take me the full afternoon to realise and find a solution.... I found the procedure "half useless"
Anyway, job is done....! Not sure I would touch a spring in a McPherson anymore !
