I'm having a problem with the rear wiper on my C5 X7 2012 Tourer. It started as an intermittent issue (my Wife told me about it, but when I tried it, it worked, so I didn't believe her!
The rear wiper doesn't work and I've got this far (see below), but would appreciate any hints before I start suspecting the loom over the tailgate.
Tried the washer, which works fine.
The wiper motor unit itself doesn't appear to be seized and isn't corroded.
I've stripped out the rear trim and disconnected the motor multiplug. I have a good earth on Green/Yellow, Nothing on Pink and 12V+ on the thin blue, regardless of the stalk switch position.
The fuse F1 in fuse box C is ok too.
Are there any relays etc lurking around for me to check?
Don't know if it helps, but when I select the "rear wiping when in reverse gear" under the menu system, it ticks the box for a second, then the tick disappears.....
Any advice warmly welcomed...
