Afternoon All,
I've had this error code appear a couple to times.
No adverse effects whilst driving, but annoying.
Checked fault with Diagbox
Manifold inlet sensor
Intermittent fault
High pressure
Short circuit to +ve.
I suspect the wiring but where
Any ideas ?
Kenny
C5 x7 P0238 error code
KennyW
- x 165
C3 1.4 petrol (SWMBO)
- x 6945
Re: C5 x7 P0238 error code
It's a combined temperature and pressure sensor Kenny. Here are the electrical characteristics, but it may be the actual sensor of course as there is a diaphragm inside that is used to sense the pressure and increase the electrical charge accordingly. The incoming air is split and channelled to both the air pressure sensor and to the NTC sensor for the temperature.
It's not uncommon for these diaphragms to wear, but the pressure range is between 300 to 3000 Mbar.
Here's the fault descriptor:
| Designation | Value | Unit |
| Supply voltage | 5 ± 0.25 | V |
| Pressure measured by the inlet air temperature and pressure sensor | Between 300 and 3000 | Mbar |
| Impedance between channels 3 and 4 (Connector disconnected, negative terminal of the ohmmeter on channel 4 ) | 15 or below | kohms |
| Impedance between channels 2 and 4 (Connector disconnected, negative terminal of the ohmmeter on channel 4 ) | 15 or below | kohms |
| Supply power | 15 maximum | mA |
| Fault Code: P0238 Description of Fault: Manifold entry pressure sensor: Short-circuit to positive, pressure too high. Voltage higher than 4.8 V during 4 acquisitions. Conditions for Fault to clear: Driving with the engine hot for 5 minutes Downgrade Modes whilst Fault is active:
Symptoms: Engine hesitating, cutting out, Lack of power, Noise. Suspect Areas:Turbocharging pressure sensor, Electrical harness, Connectors |
KennyW
- x 165
Thanks for the reply Marc,
Changed the sensor earlier this year or last year which had similar or the same problem (still have it).
I'm going to check the wiring and connectors clean same.
Will see what happens.
Kenny
viewtopic.php?p=642109#p642109
Here's my problem from earlier this year.
Are they related ?
Kenny
Are they related ?
- x 6945
You know I thought I had put some info up on this issue, now I know where!
When you changed the part, did you replace it with a half decent brand and not one from ECP? Just asking as their sensors are usually dead on arrival.
KennyW
- x 165
It was Cambiare make not from ECP.
It's possible this has become faulty any makes you would recommend
Kenny
Kenny
- x 6945
The part (1920QR) is actually £58.79 inclusive from Citroen so bear that in mind once you add shipping costs from another supplier which can be around £8-9.
Some decent brands:
Febi Bilstein
Delphi
Denso
Some decent brands:
Febi Bilstein
Delphi
Denso
KennyW
- x 165
Found Denso for £42.
Kenny
Kenny
- x 6945
Here's hoping it is the sensor then!
It may take a drive for the engine ECU to adapt to the new values it receives, so bear that in mind. Clear the fault code again and see if that rectifies it.
KennyW
- x 165
This may have been the source of my other codes I had.
We'll see when this sensor is fitted.
Kenny
Kenny
