Climate control panel C3
TELENURSE
Unread post by TELENURSE »
Im new to this forum (thank you for the add)
I've just bought a second hand C3 as a runaround, On checking but the climate control panel the direction button will only turn a quarter of a turn to the left no further
I have chased the wire back behind the panel but there are no obvious kinks and the wire hasn't snapped.
The panel appears to be from a C 4 with the 3 buttons on top of the panel not like the C3 panels I have seen with the slider on top (internal external) I have questioned this with my local dealer who wasn't sure about interchangeability between models but who advises that it could be something stuck in the heater pipe causing resistance to the dial. Before I purchase a second hand control panel and new cables is there anything else I could try.
x 3298
Re: Climate control panel C3
Hi, and :welc: to the Forum.
One thing that could help is if you were to post the vehicle VIN here (it will, for security reasons, be obscured so only Forum staff can read it). Then they can see exactly what YOUR vehicle had when she rolled out of the factory, and make sure to get you the correct part information.
