no gps signal after firmware update to 2.86
hinol
Hi Guys ,after firmware update from 2.80 to 2.86 in my 2014 508 sw GPS stopped working .No visible satellites! I was trying to update it via cd but during the process error appear and threw out the cd. Than I copied the files from the cd to 4gb memory stick and tried update via usb socket. It worked ,system updated but no gps. everything else working fine. visited local dealer and they have checked it ,according to them antenna is working fine ,it is the telamatics problem and they are not able to resolve it. Can You please advise.Thanks
- x 6957
Re: no gps signal after firmware update to 2.86
2 things:
1) 2.86 is a major firmware update and generally resets a lot of the vehicle settings to default values. This often requires the dealer to re-download and configure the RT6 Head Unit ECU / BSI from PSA servers to re-apply the correct configuration files according to the vehicle's VIN.
2) After a major update like this, it often requires a good 15 minutes of driving for the GPS system to lock onto the satellites again. Remaining static won't do this - it needs a drive of at least this time. If you have already done this (as you have been to the dealer I note), then again could be symptomatic of the firmware update / and the configuration not correct.
3) There is a test that can be done to check the GPS aerial if necessary - just plug in a cheap £10 Chinese GPS aerial into the back of the RT6 and go for a 15 minute drive - if the satellites become visible then you know it is the aerial that is shot - if not - it will have to be software or hardware related inside the unit.
hinol
Thanks for the reply.Yes the car was driven for more than 15 min also dealer checked the aerial and said it is working fine.Looks like it has to be software or hardware related inside the unit. The peugeot dealer told me that he cannot do anything more but from what You are saying a re-downlaod and configure of the RT6 unit is needed. Is there something that i can do ? Not many specialsts here in Ireland to look at it either.thanks
- x 6957
If the dealer is a Peugeot / Citroen main dealer they have the facilities to hook it up to PSA servers and download the RT6 configuration file directly to programme it - and can check relative options are correctly programmed afterwards using Diagbox. It's not something you can do as the ECU is generally locked out requiring PSA server technician access and log in. They should know this - but it depends on how experienced the dealer is on these things - most are not when it comes to telematics!
hinol
Yes.You are 100% right. I will book the car with different dealer and explained them what is the story. Do You think if they will do the update again in case mine for example was missing some files or some were corrupted (i got the cd update with the maps on ebay) it will resolve the problem? Obviously if they gonna do it they will have to configure the RT6 unit after?!
- x 6957
Yes, they will probably charge you for some diagnostic time. This will probably be about £90 for an hour roughly. If you specifically ask them to update the firmware and check the configuration afterwards, then they will have to do it via the PSA servers and apply any calibration updates necessary as part of it.
