Citroen c5 2012 cranking and not starting
mhnd25
- New User
I have a Citroen c5 2012 that has 88000 km only and it is cranking but won't start I tried changing nearly everything in the car and it didn't work it has been nearly 2 months since that I changed both the fuel pumps nearly all sensors, the cpu, the fuse box all of that didn't work i need any help i will be grateful .
EDC5
- x 130
Re: Citroen c5 2012 cranking and not starting
Did you have your new ECU coded to your key, could this be an immobiliser problem?
