307 auto drive problem
Stevey 54
Unread post by Stevey 54 »
Hi all, could anyone tell me why a Peugeot 307 automatic AL4 box would loose drive when hot? will drive ok when cool.
2004 with 80.000 on the clock.
lexi
x 134
Re: 307 auto drive problem
Unread post by lexi »
I would check oil level. You could change the oil out a few times to see if it made any difference. If no difference it could be box overhaul time with new valves. Also check for air lock on your cooling system. The auto box needs the engine cooling system to function fully, as it uses it to cool auto box.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Stevey 54
Thanks lexi, I had the oil change in mind, but never thought about the gearbox cooling system. thanks for the info.
