Xantia Rear
Jazz2001
Xantia Rear
Unread post by Jazz2001 »
I have a Xantia 1.9 TD LX 95 and would like to put rear speakers in the door cards, But seeing as my Xantia doesnt come with them will the wiring still be there? The wiring is there in the Radio Harness so any ideas as i dont particularly want to take the cards off and realise they aint there.
Jazz
IAN.D
Unread post by IAN.D »
If your car has the speaker grills in the door these just unclip (no need to remove door cards) then you can see if wires are there.
If no grills dont think there will be an easy way to check.
Jazz2001
Any idea whether all Xantias were equipped with the wiring in the rears, even tho the speakers werent fitted?
Jazz
IAN.D
I dont know but if you have a scrap yard with xantias in go take alook as door cards are often off (saves removing your own)
andycarter
Unread post by andycarter »
The speaker wiring is already there in mine.
Why not check out the rubbery thing between the door and the post, see if it has any wires in it[;)]
Jazz2001
The only Xantia i have found in Middlesbrough is a VSX and id really like to take the car to pieces and take everything out but sadly i cant, so there are no LX's
I shall have a look at the rubbery thing you speak of hopefully :D
Jazz
Dave Burns
Unread post by Dave Burns »
I have a 97 lx and they were there in mine, so was the wiring for electric rear windows, so naturally I banged a pair of them in aswell and stuck a pair of tweeters where the winder holes were, nice[^]
Dave
Jazz2001
Even better :D
Jazz
