Hi, 2010 tdi relay, no ignition lights no turn over!
Interior lights, horn, hazards, side lights all working!
All fuses checked!
Battery voltage 12.5!
Power at both fuse boxes!
Bridge out starter and engine spins over fine!
What am I missing?
Citroen relay, no ign lights, no turn over
- x 1056
Re: Citroen relay, no ign lights, no turn over
Have you checked the fusible links on top of the battery? Theres about 5 or 6 of them.
What happened? Did it cut out when driving or just not restart after switching off.
If the fusible links are ok id check to see if you have power at the ignition switch.
Triumph2
All fuses checked!
Engine switched off with the key as normal, van left for 10 mins and tried to start but no go!
gwest
- x 20
10 years for a PSA under-bonnet BSM fuse/relay unit sounds about right?
- x 1056
Relay van electrics are all Fiat based, If I remember right too they use a conventional under bonnet fusebox with separate external relays.gwest wrote: 24 Aug 2020, 05:22 10 years for a PSA under-bonnet BSM fuse/relay unit sounds about right?
